John R in Wisconsin
I have a 1950 B (serial number 258894). I use this tractor on my hobby farm. Today, while baling hay, and going down a moderate hill in 3rd gear, the tractor started freewheeling, as if it were suddenly in neutral, although the shift lever was in 3rd gear. The PTO continued working, but it's as if the tranny is no longer connected to the final drive. Now the shift lever will go into the 3rd, 5th and 6th gealr slots, but nothing happens when the clutch is engaged. Also, I cannot get the shifter to move over to the side of the quadrant where 1st, 2nd, 4th and reverse are. So the tractor will not move under it's own power at all. It rolls freely. I have no experience with transmissions but do consider myself a pretty good shade tree mechanic. I have not yet taken off the transmission cover. Does anyone have any ideas on what the problem might be, and how difficult it may be to fix? I need this tractor back in service!
