JD 2150 Hydralic Center link?
KRS_MED
have a 2150 with two hydralic couplers on rear. Like to add a hydralick center link. but how would you control two different hydralick cylinders at the same time? Like I said it has two couplers on SCV but one handle, is there a control to switch between the two? Are how could I make it work?
Keith
It sounds like you have a single Hydraulic set up,, 2 out lets (which means 2 individual hose ports)and one valve, for dual system you would have 4 hose ports, 2 valves ...if this is what you have you can get a Fasse valve set up or a second valve/couple set up.
(quoted from post at 11:42:54 06/07/14) have a 2150 with two hydraulic couplers on rear. Like to add a hydraulic center link. but how would you control two different hydraulic cylinders at the same time?
Keith
The SCV valves are modals that just bolt together side by side to add units. As txjim said it will require a duplicate of what you already have on the 2150.
What are you operating besides the hydraulic top link? Is there a front end loader on the tractor ?
SELECTIVE CONTROL VALVE (POPPET TYPE)
Cart key PART NO. PART NAME QTY SERIAL NO. 2150 2255 REMARKS
1 L56925 Grip 1 X X (SUB FOR R54274 APPL)
2 T23069 Lever 1 X
L31747 Lever 1 X
3 24H1625 Washer 1 X X 17/32" X 1" X 0.120"
4 19H1895 Cap Screw 1 X X 1/2" X 3/4"
5 R69880 Cover 1 X X
6 AR39157 Arm 1 X X
7 R394R O-Ring 1 X X (SUB FOR R65287 APPL)
8 R27218 Fitting Plug 1 X X
9 R26448 O-Ring 1 X X
10 R26149 Packing AR X X
11 R26375 O-Ring 2 X X
12 R39112 Fitting 2 X X 3/4"
13 19H1912 Cap Screw 3 X X 3/8" X 3-1/2"
14 AR26697 Sealing Washer 1 X X
15 R41155 Fitting Plug 1 X X 3/4"
16 R59882 Cam 1 X X
17 R28744 Pin 2 X X
18 R59883 Pin Fastener 1 X X
19 R70980 Cam 1 X X
20 R70981 Rocker 1 X X
21 R59881 Cam 1 X X
22 22H1025 Set Screw 4 X X 1/4" X 7/8"
23 R70982 Retainer 2 X X
24 R74695 Washer 1 X X
25 R49186 Cover 1 X X
26 R67534 Cover 1 X
27 12H304 Lock Washer 4 X X 3/8"
28 19H1731 Cap Screw 2 X X 3/8" X 1"
29 R39225 Stud 2 X X
30 34H301 Spring Pin 1 X X 7/32" X 1-1/2"
31 L40225 Stop 1 X X (SUB FOR T22996)
32 14H732 Nut 2 X X 3/8"
Operatining a disc mower and would like to beable to change angle of mower using a hydralic center link. I guess my best bit would be to use a vave to switch between the two. Would only adjust center link one or two times during use.
Thanks Keith
Never seen a three point hitch disk mower. Pull types around here with a single cylinder from one scv to raise and lower.
(quoted from post at 20:11:27 06/12/14)
Same principle. Here's a photo of a 3 pt model but on a cutter caddy
