dwag
4430 came in for hyd prob and found filings in stroke control valve as filter/screen gskt was installed wrong.Trans oil and filter was changed last winter, oil kinda dark, suction screen clean but filter housing and hyd filter had filings.(more than normal)Pulled LH axle as it was loose, brgs/brake plate OK. Shot in the dark, but does anyone have a suggestion besides complete trans/final drive disassemble? thanks, john
Tractor used on round baler.
Afraid of that plus start hunting. Nothing easy but a few Bud Lites after 5:pm ( UNLESS NEEDED SOONER) kinda dull the pain. regards, john
BLIND SQUIRREL FINDS ACORN! Shouldn"t have quit disassembly at stroke control housing, pulled pump pistons and are trashed. Solid ends are worn off making them hollow on most, so I believe "filings" prob is located. Don"t understand why ALL control valves downstream are still functioning/not scored up? Thanks for reply"s and further comments, john.
All in all about a teaspoon+ of filings found in filter housing
You will find some stuff here and there latter since this all happened on the wrong side of the filter,, Darn it
