Loader Valve recommendations?
WGreufe
I bought a model 47 loader for my 2020. I am wanting to use a spool valve on it and plumb it into the tractor mid-ship. The loader is set up to run off the rear SCVs now. Although I don't have a problem with this setup, I can't go this route on this tractor since it only has 1 SCV. Buying a spool valve will be the cheaper way to go for now since I haven't found any second SCV kits that aren't crazy expensive. :(
Can anyone give any recommendation on a spool valve? I don't want to buy junk but I am not going to be using this tractor daily since it's only a hobby. I found this unit here but not sure what the quality is like. I don't mind using the standard two lever spool valves, joy sticks are nice but I grew up using the standard two lever so I am used to it.
http://www.northerntool.com/shop/tools/product_200314957_200314957
Thanks for any advice you can give me. Wade
That valve will work,but you need to purchase the closed center plug and crank the relief valve down tight.
(quoted from post at 09:44:20 06/09/14) That valve will work,but you need to purchase the closed center plug and crank the relief valve down tight.
Is there another spool valve that anyone recommends?
For a JD 2020 I'd pick a lower GPM flow that would give better feathering of cylinders capability plus I prefer JS valve over 2 levers. This valve is from Surplus Center.
I've bought stuff from Surplus Center for years and have had excellent service from them and their products. Good quality stuff at good prices. They have a tech line if you are not sure what you need. I have a standard valve on my loader tractor that I converted to joystick to eliminate the actual valve by the seat. Works great. I bought it from SC. Mike
To utilize a CCLS valve tractor must have a CCLS hyd system which your tractor does have. The only tractors I personally know of with CCLS hyd are Ford-NH but there could be more
WGreufe... I have a complete 2 spool closed center valve with the correct mounting bracket for your 47. I am taking it off my 47 so I can put it on another tractor that is open center and running the loader off the tractor remotes... My loader came off a 2020 John Deere so it should bolt right up for you. Email me if your interested.
