Clutch stuck on JD 420
Dad"s 430 was stuck and an old JD service mgr. told him to get it rolling down a hill and with the tranny in high gear to pop the clutch. It worked.
Tie the clutch petal down and leave it for a week, if nothing, hold it down and have somebody pull you around in 4th gear, step on the brakes now and then.
I had a 420 clutch stick the day after I bought it at a farm auction.Messed with it for a week then decided to split it.It only took a couple hours to install a new clutch disc.It didn't have live pto,a lot easier to work on.
Our old 8N stuck every once in a while. Put it in high gear, tie the clutch down and have some one pull you (SLOWLY! <5 mph) in 5th gear while you bump the brakes occasionally. Figure 8's for a driving path seem to work a little better, for some reason.
