I bought a model 47 loader for my 2020. I am wanting to use a spool valve on it and plumb it into the tractor mid-ship. The loader is set up to run off the rear SCVs now. Although I don't have a problem with this setup, I can't go this route on this tractor since it only has 1 SCV. Buying a spool valve will be the cheaper way to go for now since I haven't found any second SCV kits that aren't crazy expensive.
Can anyone give any recommendation on a spool valve? I don't want to buy junk but I am not going to be using this tractor daily since it's only a hobby. I found this unit here but not sure what the quality is like. I don't mind using the standard two lever spool valves, joy sticks are nice but I grew up using the standard two lever so I am used to it.
http://www.northerntool.com/shop/tools/product_200314957_200314957
Thanks for any advice you can give me. Wade
