4020rear main seal housing
Order new one from Deere.Sent me part no.R530322.Is this the right housing? Bolt pattern the same but not drilled for dowel pins on block.Do I drill the housing or remove the pins if it the right one?Part book shows it fitting combine on Deere search.
The newer modles don't use a dowel pin, which makes seal alinement a chalenge, I leave the bolts loose and install the seal, then tighten the bolts letting the seal line up the housing.
They are ornery to install with out the "handy-Dandy" tool, you need to tap the center "wiper" ring on and the outer seal housing a bit at a time till the inner ring is flush with the crank, then tap the outer seal housing in a bit farther with a small punch.
