Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 4020rear main seal housing
Tim S
06-08-2014 15:45:53
The newer modles don't use a dowel pin, which makes seal alinement a chalenge, I leave the bolts loose and install the seal, then tighten the bolts letting the seal line up the housing.
06-08-2014 17:02:36
 Re: 4020rear main seal housing in reply to Tim S, 06-08-2014 15:45:53
So you would remove dowels?
Tim S
06-08-2014 18:20:54
 Re: 4020rear main seal housing in reply to toomanytoys, 06-08-2014 17:02:36
06-09-2014 11:03:42
 Re: 4020rear main seal housing in reply to Tim S, 06-08-2014 18:20:54
How far in do you install new type seal such as letting it bottom out or certain distance from end of crank
Tim S
06-09-2014 12:41:24
 Re: 4020rear main seal housing in reply to toomanytoys, 06-09-2014 11:03:42
They are ornery to install with out the "handy-Dandy" tool, you need to tap the center "wiper" ring on and the outer seal housing a bit at a time till the inner ring is flush with the crank, then tap the outer seal housing in a bit farther with a small punch.
