TractorLinks.com
Show Parts for Model:
Re: JD 2150 Hydraulic Center link?
buickanddeere
06-08-2014 06:40:27
KRS_MED said: (quoted from post at 11:42:54 06/07/14) have a 2150 with two hydraulic couplers on rear. Like to add a hydraulic center link. but how would you control two different hydraulic cylinders at the same time?
Like I said it has two couplers on SCV but one handle, is there a control to switch between the two? Are how could I make it work?
Keith
The SCV valves are modals that just bolt together side by side to add units. As txjim said it will require a duplicate of what you already have on the 2150.
What are you operating besides the hydraulic top link? Is there a front end loader on the tractor ?
SELECTIVE CONTROL VALVE (POPPET TYPE)
Cart key PART NO. PART NAME QTY SERIAL NO. 2150 2255 REMARKS
1 L56925 Grip 1 X X (SUB FOR R54274 APPL)
2 T23069 Lever 1 X
L31747 Lever 1 X
3 24H1625 Washer 1 X X 17/32" X 1" X 0.120"
4 19H1895 Cap Screw 1 X X 1/2" X 3/4"
5 R69880 Cover 1 X X
6 AR39157 Arm 1 X X
7 R394R O-Ring 1 X X (SUB FOR R65287 APPL)
8 R27218 Fitting Plug 1 X X
9 R26448 O-Ring 1 X X
10 R26149 Packing AR X X
11 R26375 O-Ring 2 X X
12 R39112 Fitting 2 X X 3/4"
13 19H1912 Cap Screw 3 X X 3/8" X 3-1/2"
14 AR26697 Sealing Washer 1 X X
15 R41155 Fitting Plug 1 X X 3/4"
16 R59882 Cam 1 X X
17 R28744 Pin 2 X X
18 R59883 Pin Fastener 1 X X
19 R70980 Cam 1 X X
20 R70981 Rocker 1 X X
21 R59881 Cam 1 X X
22 22H1025 Set Screw 4 X X 1/4" X 7/8"
23 R70982 Retainer 2 X X
24 R74695 Washer 1 X X
25 R49186 Cover 1 X X
26 R67534 Cover 1 X
27 12H304 Lock Washer 4 X X 3/8"
28 19H1731 Cap Screw 2 X X 3/8" X 1"
29 R39225 Stud 2 X X
30 34H301 Spring Pin 1 X X 7/32" X 1-1/2"
31 L40225 Stop 1 X X (SUB FOR T22996)
32 14H732 Nut 2 X X 3/8"
This post was edited by buickanddeere at 06:40:43 06/08/14.
