Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
carb
Danny in Draketown
06-08-2014 06:22:32
67.142.172.24
1952 John Deere A.a couple weeks ago I inquired on what I thought was a spark plug problem,due to the tractor breaking up under a load. I pull the tractor and at low rpm pulls great. when I throttle it up it starts to break up. gtx1967 chimed in with the consideration of a starving for fuel problem. has good flow to the carb, but when I opened the drain nothing came out till I poked a wire in it to open it up. hard telling whats all going on in there. does any one have any good(printable) info on the carburetor, I would appreciate any and all.
[Reply]   [No Email]
Danny in Draketown
06-09-2014 05:52:25
67.142.172.23
 Re: carb in reply to Danny in Draketown, 06-08-2014 06:22:32
o.k pulled the bowl off, it has 2 gaskets on it. opened the fuel strainer and that gasket is history. didn't see a gasket set on this site. but Roberts has a gasket set for DLTX series for $7 . its a 1952 I think. cant read the serial #. any way to tell which carb it actually is
[Reply]  [No Email]
Danny in Draketown
06-08-2014 17:05:40
67.142.172.25
gtx your reply said no e-mail so I cant do that thru here.do you think it could be something so simple as a cleaning. and lee b had a good point about just some build up in there. I never had trouble with it except the last 2 pulls. I would rather try the simple stuff before a complete tear down and rebuild
[Reply]  [No Email]
Gtx1967jewison
06-08-2014 19:38:57
70.197.192.141
 Re: carb in reply to Danny in Draketown, 06-08-2014 17:05:40
It's likely just 2 simple things to clean. Remove the bowl & clean it without disturbing the float setting, and pull the nozzle out of the stem & clean in there & the holes in the nozzle itself. That should take care of it & if not you'll need to clean a few other things. I'm not sure how to turn on emails but It should be there now on this post.
[Reply]  [No Email]
Gtx1967jewison
06-08-2014 13:47:51
70.197.192.141
If you need help or some pointers you can call me I've done quite a few of those carbs with good results. They're pretty simple as far as carbs go if you know a few things about them. Parts are ez to get also. There's also several places to send them if you'd rather do that. Send me an email & I'll give you my phone # if you'd like.
[Reply]  [No Email]
Lee B
06-08-2014 13:00:01
64.37.27.155
Mason bees and small wasps will often fill such a hole with a nest or partial nest anyway, I wouldn't think it requires a carburetor overhaul just because of that. Check the drain hole on your magneto cap area while I'm thinking about those bees, they rusted mine several times that way till I filled the hole with the filter off of a used cigarette.
Have you tried to open the load screw 1/4 of a turn and give it another run down the track? You may have the idle side set too rich compensating for a too lean setting on the load screw as well. Back in the days when I was leaving gas in the tank or carb for that matter, I got into the habit of opening the needles and returning them to their original position before start up just to save time doing that same thing once I tried to work it a little. Varnish forms on the sides of the needles and cracking them loose like that allows fresh gas in there to dissolve it away. Since I've left both the carb and tank dry when done with it anymore, I don't have to do even this much. Gasoline has always formed gum, varnish, and gone bad in a real stinky manner - it's not the ethanol doing it. Leave them dry and save yourself some hassles.
[Reply]  [No Email]
Jo Bird
06-08-2014 07:12:27
65.37.20.182
Check out Roberts Carburetor Repair online..
[Reply]  [No Email]
BushogPapa
06-08-2014 06:37:59
173.88.50.145
You may be surprised at what all junk could be in that float bowl..!
Just do not wrench hard on that bottom nut..you can break the casting and that is expensive..! Be sure to clean the fuel screen in the well, on top of the carb, too..
If you treat it carefully, you may not need a new float-bowl gasket..usually a few light taps, with the bottom nut loose will have the float bowl ready to drop off.
Ron
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
