TractorLinks.com
Show Parts for Model:
Re: Early 4020 Injector pump rebuild
jdemaris
06-08-2014 06:10:45
I don't know which pump you have. If an early or late DB - sounds like a typical plastic-dampener failure. $50 in parts to fix and labor depends on who does it. Takes 2 hours on the bench.
If a C model pump - there is a rack and pinion gear set that runs the throttle. Very common for it to dry up and the gears wear out. Sometimes a half-hour fix if you can flip the pinion gear over half-way and use the unworn gear teeth.
MaverickM23
06-08-2014 06:34:14
 Re: Early 4020 Injector pump rebuild in reply to jdemaris, 06-08-2014 06:10:45
The numbers on the pump are DBGVC 633 3AJ. Don't know if I should attempt the fix myself or have someone do it, or buy a rebuilt one. The tractor had been loping at low idle lately before this happened.
jdemaris
06-08-2014 18:50:57
 Re: Early 4020 Injector pump rebuild in reply to MaverickM23, 06-08-2014 06:34:14
The DBGVC stands for "die cast model B, centrifugal governor, vertical mount, clockwise" as I recall.
All the parts come to around $50. For a first timer with a tech manual - it's easy to spend a full day on it. To a person with experience - 1 to 2 hours.
It is no more complicated that rebuilding a Rochester Quadrajet carburetor. Not easy but not that difficult either if careful. No special tools needed other then one special wrench that will cost you $10.
Depends if you want a learning experience . . or just want it fixed and don't want to risk it yourself. A pump shop will not "rebuild" it. They will replace small parts and likely leave the major moving parts as-is. Typical charge is $400 to $700.
