3020 hyd. pump
It looks like I am going to have to break down and pull the hyd. pump on my 3020 because of a major leak. My shop manual says to pull the front end and go from the bottom. I have been told that the fuel tank can be pulled and work from the top.What are your thoughts/opinions/experiences on this? Thanks for any help on this, the knowledge on this board always amazes me. Thanks Lee
Take it out the bottom, remove all the lines including the one on top, take the frame loose at the engine and with a little help and a 4ft 2X4 let it down out..
The 3020 used the 2000 series pump in either the 40cm/2.4cu" or 50cm/3.0cu" sized.
There is a bolt in swap to the 65cm/4cu" 2000 series pump optional in the 4000,4020,4320,4520,4620,4230,4430,4630,4040,4240,4440,4640 etc
