steering arm
On a 2020, can the steering arm (pitman arm) be changed without pulling the steering box out. There is an inspection hole with cover and the bolt holding the arm onto the shaft of the steering box can be removed. It just doesn"t look like there is enough room to slide it off the shaft and remove it. Thanks
I think you can leave the box on, but you will need to remove the cover on the other side and pull the pin out then turn the wheel enough to let the shaft clear it and pull the shaft to you enough to let the arm drop down,, check for a timing mark first, if you can't find one make one..
