Ok, as I said in a previous post, my 2 cyl 820 is leaking oil at the clutch. I took it all apart and the oil slinger grooves were clean and the drain hole at the bottom is clear. The oil slinger is a bit worn down and the dust shield is a bit worn down as well. They don't seem to be available anywhere I look. What would my options be? Also, the clutch operating sleeve seems a bit loose on the pulley shaft. Would that cause leaks too? Is there a bushing in there or is that just machined to fit. Does a wee bit of play matter otherwise? Next question, my drive gear on the sliding gear shaft is a wee bit loose. It is held on by a castellated nut with a cotter pin. Does that mean its not supposed to be %100 tight? To me it seems that should be tight, but that is throwing me off and the manual doesn't say nothing about that. It just says to install drive gear... Any advice would be appreciated. Thanks
