Hyd Valve Seat on 4010 Rockshaft cover
I have to replace the valve seat R27211 on the rockshaft cover for my 4010. it is down a deep, small diameter bore. How does one remove the old one and install the new one? This is on the earlier style cover that contains the relief valve for the rockshaft.
thanks,
If it were my tractor I just get the newer style piston cover part # R32386 which is subbed for earlier cover.
R27778 COVER 1 - 038199 (SUB 19H2357, R32386 AND AR31754)
Farm Jack,
Did you ever replace the seat / valve in your early rockshaft valve cover? I am in the same boat. Was thinking maybe I could just replace the valve and shim it a little tighter. What did you end up doing?
