what are 3020 front weights worth?
Ray
Selling a 3020 and the guy doesn't want the front weights.I have 4 slabs,plus the side starter weights.Don't have any idea what there worth.
Other's will surely chime in - I feel I've been lucky and bought starters for $75 a piece ($150 for the set) - then sometimes slabs for $50 a piece. But they usually go for more then that...depends how hard and long you look.
It used to be $.50 a pound around here. Now most I"ve seen them sell for is at the most $20 a piece. I see people advertising them all the time for much more but they never end up getting someone to pay that much. The double front style are hard to find however and are worth more.
They weigh 81#s and I have sold many of them for $50 each.The correct double threaded bolts that go in frame are spendy from JD.They used to be more just collecting dust.I was at a sale where auctioneer clearly stated so much per weight and there were 5 lying there and guy started them at $125 and was pretty proud until he realized his mistake.When he complained to auctioneer he was asked how old he was and told to listen next time .
Some info for you- slabs-in the Ohio area you can get at least 50 cents a pound for slabs in good shape (no chips or breaks in the area where the carriage bolts go), so $40 anyway. Mounting studs- don’t give these away, I think the spendy JD ones Larryanderson refers to cost $30 apiece. Starter pads- unsure of the weight of these but generally see them going for $150 a set. There is a recent thread here talking about the ones with the one inch hole on the side. They are apparently worth a little more than the ones without a hole. Thinking the casting # is R51644. Thinking the non-hole is #R27643. I’d say you could get $325-350 for your set if you shopped them around for a bit and included the hardware.
