johndeereman
How long will the penny trick work? I put the penny in and it didn"t work at first so I was reading in the operators manual about switching shafts. The manual said when putting the 540 shaft on to make sure the spring loaded shaft goes all the way in of course it didn"t so I rotated the pto till it went in a little further put the penny in bolted stub shaft on and all acts normal now. Now I"m wondering if I really need the penny? Thinkin it"s possible that everything got out of wack when shaft loosened up. The stub shaft isn"t worn at all looks like I need fresh bolts though and possibly some loctite.
