mr.precision
I removed the clutch fork assembly from my 1950 Model B in order to determine the source of slop in the clutch lever. The factory manual is vague about the following:
1. Is there a replaceable bushing in the housing that the splined shaft passes through?
2. Is some play in the shaft/fork splines normal? Is this area to be greased on re-assembly (seems a light coat of grease would be correct)?
3. The manual says to pour 1/2 quart of motor oil behind the "dam" on the inner clutch pulley housing cover. I cannot see any trace of oil there (it wasn't removed) and looking at the parts book, I don't see how oil could get in there when the motor oil is changed. If there is no oil there, should I just pour 1/2 quart behind the dam anyway?
I am enjoying work on this old girl, but am amazed how vague some of the instructions are in the factory shop manual.
Thanks in advance-
Mike
Thanks in advance-
Mike
