A few days ago I posted on here about an ignition issue with a 630. First of all, thank you everyone for helping out an amateur. Anyways, I turned the ignition switch on and put my test light on the coil's high side terminal and got a light. So then I put the test light on the distributor terminal and started to crank and I got a light. So the tractor is getting juice all the way down into the distributor. I suppose the next place I look is the condenser and points? My grandpa had this tractor worked on about five years ago and I know that they replaced both of those back then.
Since I already put new spark plugs in, the only other thing I know to try is to put in fresh gas. The current gas is a couple years old and doesn"t smell like varnish and has a good color. Otherwise I don"t know where or what to turn to next?
