I am looking at a 2240 to buy.. It has a PTO problem. The PTO lever on the right side below the seat is kinda hard to move, but will travel the full length and will engage or disengage the PTO (forward on, back off) . The center lever you pull up on has no effect on the PTO operation, i.e. the PTO is entirely dependent on the right hand lever regardless of the center consol level position (up or down).. The center lever has full travel and you can feel some gears meshing but nothing changes. Only the right lever below the seat will engage the PTO. I'm thinking that the center lever is not fully disengaging like it is supposed to.
The tractor was split and clutch/transmission work was done 3 yrs ago by a good mechanic and inspected for other problems which were fixed. The owner says the center console switch worked last year when he used it to bale hay..
Any ideas if this is an easy (possibly) fix??
