Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Two cylinder tractor size
04-15-2014 20:10:18
I don't where you are going to find two 80/820/830 for under $12,000-$15,000 each. Then the time and money to hack them up into a tandem hitch . You are well into paying for a 4455M4WD by that point. The 4455 has diff lock, sound guard body , high flow hydrualics, 1000rpm pto, three point hitch and air conditioning. Add those to your 830 tandem hitch for less than the price of a 4455.
Care to guess that the price difference would be on a tandem 830 hitch at an auction vs a 4455M4WD at your retirement?
The M4WD was used as a comparison as it's driving on two axles like the jackleg tandem 830 hitch. You were watching a strain gauge and mph indicator? Or watching the tractors from the side of the field? I'll take science over a seat of the pants dyno.
Where pray tell did 400cu" and 500HP come from ??? The 4455 has a 466 cu" engine making less than 150 net Hp.
The 450HP engine with 1200 cu" you like Is being pushed 119% harder than the 466 making 147pto Hp.
04-15-2014 21:02:46
 Re: Two cylinder tractor size in reply to buickanddeere, 04-15-2014 20:10:18
The M&W dyno shows only the engines output, not the whole machines ability to perform useful work. When you stand & watch the 830 pull the same load in the same field at the same rate as the 4020, I don't care what the dyno says cuz it doesn't matter. You have to put it to the ground & burn the same fuel. Perhaps we should remove your turbo & find a N.A. 6 cyl Diesel that can do the work of an 830 on the same fuel, apples to apples. It don't exist, at least not a Deere .
04-15-2014 20:53:53
The 400ci @ 500 hp is running all over Tarnation, mostly at classic car shows & drag strips. V-8 gas/ethanol. The 1200ci @ 400 hp is in reference to a semi truck engine, which I was also with the 500hp 400ci v-8 gas. Making a point that hp is not always the same, torque matters. And on your note about which is being pushed, using your 830's & your 4455, they have over 900ci, your 4455 has only 466. The output is the same.
04-15-2014 20:47:04
To Buick, and you, please go back & read my tandem hitch post. I said to tandem two R's, which you can buy several a day for 3-5,000. NOT two 830's. I also said in comparison to a 2wd ,100hp tractor. It's a fact that the 2 R's combined can only burn just over 4 gph at rated load. I don't know what a 4230 would burn, or a 4020, loaded to 100hp, but I'd bet it's more than 8 or 9 gph. And nobody can tell me that a tandem R with duals all around has less traction than even buicks 4455 front-
assist. Again I said a 2wd single 100hp tractor.
