Any experience with a IH 420 plow...
phess11
Never used one before.
The guy above is pulling your leg. That plow should be a good match for a 630 and work fine. The backbone looks like 4X6 which is a lot heavier than a lot of 3 bottom 3 pt hitch plows.
It is 3-16s and is Category 1. Had to get bushings to make it fit correctly to Category 2. Looking forward to the ground drying out a little to set it up and try it out.
Thanks,
phil
Cat. 1 plows are generally built a little lighter than cat. 2 plows. But it still looks like a really heavy built backbone. And a lot of reliability problems with implements has more to do with the nut behind the steering wheel. lol!
I am speaking from personal experience here. (smile)
