Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Tim S
04-14-2014 16:53:41
You can run a power beyond block that fits in behind the SCV, get your pressure and return ports there, will work out good,,better than running through the SCV's and cheaper than a Fasse valve..
04-14-2014 17:18:03
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to Tim S, 04-14-2014 16:53:41
Wouldn't I have to run a joystick then?
04-14-2014 17:51:53
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to TIMAR, 04-14-2014 17:18:03
Once you swap it over to a joystick with a dedicated supply and return line. You will wonder why anyone tries to operate a loader boom and bucket from the scv's.
Tim S
04-14-2014 17:54:43
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to buickanddeere, 04-14-2014 17:51:53
04-14-2014 18:22:45
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to Tim S, 04-14-2014 17:54:43
I agree with both of you, but I am looking at cost for the customer. That said, I used to run our 740 loader with the scv levers until I bought a 4445 with a joystick already installed. Running the loader with the console levers for me was an easy one hand operation
I can buy 2 Fasse valves for less than $1000 and just mount the switches in the cab. Can't find a factory SGB joystick for sale, and a CROSS joystick, cables, fittings and the adapters will cost over $1000 plus a lost more labor.
Mike Aylward
04-15-2014 06:22:19
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to TIMAR, 04-14-2014 18:22:45
I just looked at the Surplus Center site and a valve can be had for around $250, a joystick controller for about $120-150, adaptors for the cables for the stick are about $33 each. Cables aren't too expensive, either. You could have a really nice setup for $500-600. Mike
04-15-2014 10:32:54
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to Mike Aylward, 04-15-2014 06:22:19
Thanks. I'll check that out.
