318 Hydrostat Filter
http://www.wixfilters.com/Lookup/Applications.aspx?Section=4
Does it meet these specs ?
zoom
Part Number: 51410
UPC Number: 765809514102
Principle Application: Ariens, Bolen, Case, IHC, John Deere, Kohler, Toro, Other
Applications
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 3.79
Outer Diameter Top: 3.66
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 325
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
Gasket Diameters Number O.D. I.D. Thk.
Attached 2.729 2.415 0.2
