Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4440 PORTED RETURN OIL FILTER COVER ?
Tx Jim
04-14-2014 12:19:59
You could also tee into one of these return line fittings cheaper than ported filter cover. Also then wouldn't have to contend with a hose in the way when changing hyd filter.
TIMAR
04-14-2014 16:44:42
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to Tx Jim, 04-14-2014 12:19:59
Ya,that looks like a better deal. May just buy 2 Fasse valves and run the loader from the two boxes. Customer needs 3 outlets but that will cost way more upfront in parts, then there is bout 4hrs of labor. He doesn't need to use the loader when he is swathing or baling, so he can just switch both Fasse valves to no. 2 ports
Tim S
04-14-2014 16:53:41
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to TIMAR, 04-14-2014 16:44:42
You can run a power beyond block that fits in behind the SCV, get your pressure and return ports there, will work out good,,better than running through the SCV's and cheaper than a Fasse valve..
TIMAR
04-14-2014 17:18:03
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to Tim S, 04-14-2014 16:53:41
Wouldn't I have to run a joystick then?
buickanddeere
04-14-2014 17:51:53
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to TIMAR, 04-14-2014 17:18:03
Once you swap it over to a joystick with a dedicated supply and return line. You will wonder why anyone tries to operate a loader boom and bucket from the scv's.
Tim S
04-14-2014 17:54:43
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to buickanddeere, 04-14-2014 17:51:53
Exactly....
TIMAR
04-14-2014 18:22:45
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to Tim S, 04-14-2014 17:54:43
I agree with both of you, but I am looking at cost for the customer. That said, I used to run our 740 loader with the scv levers until I bought a 4445 with a joystick already installed. Running the loader with the console levers for me was an easy one hand operation
I can buy 2 Fasse valves for less than $1000 and just mount the switches in the cab. Can't find a factory SGB joystick for sale, and a CROSS joystick, cables, fittings and the adapters will cost over $1000 plus a lost more labor.
Mike Aylward
04-15-2014 06:22:19
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to TIMAR, 04-14-2014 18:22:45
I just looked at the Surplus Center site and a valve can be had for around $250, a joystick controller for about $120-150, adaptors for the cables for the stick are about $33 each. Cables aren't too expensive, either. You could have a really nice setup for $500-600. Mike
TIMAR
04-15-2014 10:32:54
 Re: 4440 PORTED RETURN OIL FILTER COVER ? in reply to Mike Aylward, 04-15-2014 06:22:19
Thanks. I'll check that out.
