TractorLinks.com
Show Parts for Model:
Re: 2510-4020 Front Weights
Railer
04-14-2014 11:59:54
So, did I pick up a ‘mixed set” of starters (one side with a hole and one side without)? Or if the quik tach cultivator theory is good, what is the correct side of the tractor to put the hole on?
jd_adict
04-14-2014 17:11:26
 Re: 2510-4020 Front Weights in reply to Railer, 04-14-2014 11:59:54
would just like to put in my opinions. first off yes, there was two different kinds of front cast side weights for these tractors. the earlier ones had no holes, the later side console models had a hole in them like you described. I have several sets of each on tractors. I also have some of each that have been broke, but the ones with the hole in them break by the hole. finally they are interchangeable because they fit from side to side. what you have is a mixed match set. an ad on this web site will probably get you a correct one if someone else has a mixed match set. The side weights WITH the holes are harder to find. regardless of holes or no holes, they look awesome on the tractor. Hope this info helps.
