Yesterday's Tractor Co. Restoration Quality Tractor Parts
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
JD 4020 Gaulded piston
Dougin texas
04-14-2014 07:24:21
216.201.184.190
I recently pulled the head off my JD 4020 expecting to find a bad head gasket, instead found 2 gaulded pistons, Pulled main and rod bearings all look good. Any idea what would have caused this?
[Reply]   [No Email]
ET
04-15-2014 08:32:30
134.179.104.127
 Re: JD 4020 Gaulded piston in reply to Dougin texas, 04-14-2014 07:24:21
Not allowing the motor to warm up and hitting it with a heavy load can cause that type of scoring. Improper use of a dynometer on a new engine will do it.
[Reply]  [No Email]
D-
04-14-2014 16:30:55
166.137.248.107
If it's that "four cornered" scoring that supposedly is from mismatched pistons/sleeves. We had to overhaul several new '72 4020s and that's when Deere started matching pistons to sleeves.
Still I have seen those score a year later and those that weren't overhauled score several years later. The odd thing is I have never seen anyones aftermarket sets have that type scoring.
If you have scoring on the sides that is probably from overheating.
You should remove the bottom of the pump and let the gear come out to check housing and gear wear. Many times if they are OK you might have to replace the drive gear. Also look at the cam gear that drives the oil pump. It will probably have steps worn on the teeth and maybe even have sharp teeth.
[Reply]  [No Email]
Tim S
04-14-2014 07:29:11
107.128.253.113
A lot of times it"s because of a bad injector, shooting a bad spray pattern,,and some times it just "happens"...Darn it..be sure to replace your wrist pin bushings and have your rods re-sized..
[Reply]  [No Email]
Dougin texas
04-14-2014 10:06:28
216.201.184.190
 Re: JD 4020 Gaulded piston in reply to Tim S, 04-14-2014 07:29:11
I am planning on replacing all injectors.
I have ordered an inframe OH kit, do you think I should do anything with oil pump? Always had good oil pressure.
[Reply]  [No Email]
Tim S
04-14-2014 10:48:47
107.128.253.113
 Re: JD 4020 Gaulded piston in reply to Dougin texas, 04-14-2014 10:06:28
You should be fine on the oil pump..
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
