Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 1964 3020 Governor Tube
Bob
04-13-2014 20:50:31
The crankcase ventilator has been disabled.
I wonder if they removed the impeller, as well (from the drive end of the governor)?
At some point it was determined they were not needed.
They pulled air from the intake tube, (after the air filter) and pushed crankcase gasses out the vent tube (the opposite of how most PCV systems work).
NOT sure why they were eliminated in later tractors, and often disabled in older units, but it PROBABLY has to do with the advent of better/modern detergent oils that help eliminate sludge buildup.
tomstractorsandtoys
04-14-2014 18:28:59
 Re: 1964 3020 Governor Tube in reply to Bob, 04-13-2014 20:50:31
The reason is they sometimes do bad things,like pumping the intake full of engine oil.I started a 3010 from the ground and was right beside the starter when ours did that and it was quite the experience when the head gasket blew and oil went everywhere.The gasket was blown out from under the head.
Copyright © 1997-2015 Yesterday's Tractor Co.
