Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: john deere 70 loud engine noise
grandad..
04-11-2014 05:51:27
I have the reduction housing off. What is all involved in checking that main bearing on that side. Can I just pull that cast housing off and check the bearing. Also whats the easiest way to pull that inside gear off the crank?? Thanks in advance
Blksmok
04-11-2014 10:24:04
 Re: john deere 70 loud engine noise in reply to grandad.., 04-11-2014 05:51:27
granddad...check the rod bearings first. Much easier than checking the mains. I assume this a gas model? You can check the rod bearings through the top crankcase cover. If your has a center main bearing, you need to pull that out with the crankshaft. If the engine runs ok cold at idle and starts to labor as it warms up...bearings.
ET
04-11-2014 06:44:05
Pull the crankcase cover off and look for a broken oil line to the main bearing behind the clutch. Look for any broken oil lines in there.
