TractorLinks.com
Show Parts for Model:
Re: JOHN DEERE 4630 Quad Range tran pump suction screen location
Tx Jim
04-11-2014 04:31:45
Does power steering operate correctly? While you're waiting on pressure gauge you might consider checking to see if priority valve(parts keys #2-#7A or 7B) is stuck which could also limit pressure to RS & SCV's
This post was edited by Tx Jim at 04:37:42 04/11/14.
Readytoretire
04-11-2014 10:54:24
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen location in reply to Tx Jim, 04-11-2014 04:31:45
Yes everything else works good ,steering, brakes, shifting, PTO, just the 3 point is real slow coming up with no load and the hydraulic cyl. will only raise the disk about 2 inches for about 5 tries after being first cranked cold and then will not do that much. The cyl. will hold the disk as far as the hydraulics will raise it, so I figure the cyl. is good if not, when I let off on the lever after getting it up 2 inches the disk would lower itself. From what I can gather from reading on it, the tractor will run fine without the hydraulic cyl. and 3 point working. If I can not find the problem soon I will put my 12V dump bed hyd. pump on the disk to raise and lower it to get the ground ready for soybeans. Then go into the main pump when I have time this summer. Thanks
Tim S
04-11-2014 12:00:45
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen location in reply to Readytoretire, 04-11-2014 10:54:24
My thought is to turn the pump screw in a couple of rounds and see if it gets the pressure up to over come the priority valve...
Tx Jim
04-11-2014 14:02:00
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen loca in reply to Tim S, 04-11-2014 12:00:45
Stroke control screw is parts key #37,loosen lock(#36) turn screw CW a couple of turns as Tim suggested.
