1957 420 John Deere cuts off under load.
Dsmythe
I have a 1957 John deere 420 tractor that cuts off under a load or just going up a steep hill. When I disengage the clutch it just seems weaker and stops. It will restart without any problem. I usually have to shift into a lower gear to continue up the hill. I don't have a clue about this( Obviously ). Will you all PLEASE help?
Thank you in advance, Dsmythe
Check the points and plugs for proper gap, check the timing, and make sure you have plenty of fuel flow to the carb, and adjust the carb like its sopposed to be.
