TractorLinks.com
Show Parts for Model:
Re: JOHN DEERE 4630 Quad Range tran pump suction screen location
Tim S
04-10-2014 16:29:19
I'm just now reading about your problem,, what is your stand by pressure measured at your SCV ??My guess is it is near or below 1750psi,, in this case your priority valve is limiting your rear pressure and flow,, see if you can turn the pressure adjusting screw in (Clock wise) to increase your stand by pressure to 2250psi...This adjusting screw is on the underside of the front pump it takes a 3/4" wrench to loosen the jam nut and an Allen wrench to turn the screw.
Readytoretire
04-10-2014 17:33:21
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen location in reply to Tim S, 04-10-2014 16:29:19
Waiting on a 5000PSI gauge to come in before I can check it. Thanks
Tx Jim
04-11-2014 04:31:45
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen location in reply to Readytoretire, 04-10-2014 17:33:21
Does power steering operate correctly? While you're waiting on pressure gauge you might consider checking to see if priority valve(parts keys #2-#7A or 7B) is stuck which could also limit pressure to RS & SCV's
This post was edited by Tx Jim at 04:37:42 04/11/14.
Readytoretire
04-11-2014 10:54:24
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen location in reply to Tx Jim, 04-11-2014 04:31:45
Yes everything else works good ,steering, brakes, shifting, PTO, just the 3 point is real slow coming up with no load and the hydraulic cyl. will only raise the disk about 2 inches for about 5 tries after being first cranked cold and then will not do that much. The cyl. will hold the disk as far as the hydraulics will raise it, so I figure the cyl. is good if not, when I let off on the lever after getting it up 2 inches the disk would lower itself. From what I can gather from reading on it, the tractor will run fine without the hydraulic cyl. and 3 point working. If I can not find the problem soon I will put my 12V dump bed hyd. pump on the disk to raise and lower it to get the ground ready for soybeans. Then go into the main pump when I have time this summer. Thanks
Tim S
04-11-2014 12:00:45
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen location in reply to Readytoretire, 04-11-2014 10:54:24
My thought is to turn the pump screw in a couple of rounds and see if it gets the pressure up to over come the priority valve...
Tx Jim
04-11-2014 14:02:00
 Re: JOHN DEERE 4630 Quad Range tran pump suction screen loca in reply to Tim S, 04-11-2014 12:00:45
Stroke control screw is parts key #37,loosen lock(#36) turn screw CW a couple of turns as Tim suggested.
