Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 3020 front steering unit hydraulic leak?
Tim S
04-10-2014 13:46:59
Your steer motor needs rebuilt, the piston seals are failing allowing more oil into the pinion area than the return line can handle, it probably darts on the road too.. you will need to drop the front axle and remove one of the side frames to repair it,, we can walk you through it if you can handle removing the front axle okay..
Bruce 4447
04-10-2014 18:50:09
 Re: 3020 front steering unit hydraulic leak? in reply to Tim S, 04-10-2014 13:46:59
Thanks, Tim. The tractor doesn't dart on the road, but I haven't driven it since I noticed the leak (a pretty steady "drizzle") right after some heavy manure pile work. I didn't notice any leak before that. It has a loader on it. I haven't gone out to that ranch today to eyeball it. I'm guessing the loader might have to come off, correct?
Tim S
04-10-2014 19:13:59
 Re: 3020 front steering unit hydraulic leak? in reply to Bruce 4447, 04-10-2014 18:50:09
Yes it will to get a side frame off...
