Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Pitting in o-ring groove in JD 6-404 engine block - Opti
JD Dave
04-04-2014 17:24:59
Can you explain how this machining is done? If you machine away to eliminate the pitting at the upper liner o-ring in the block won't this alter the liner protrusion dimension at the deck?
Kent Petersen
04-05-2014 00:16:14
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to JD Dave, 04-04-2014 17:24:59
J D Dave no the liner is set by the depth in the top of the block. the counter bores are cut out with a boreing bar a ledge is left in the bottom and a new counter bore is installed
04-04-2014 19:14:51
This is exactly what I was wondering. How would it be possible to ensure that the standard length liners protrude within the correct tolerances? Hmm.
I've heard the JB weld method mentioned before. I've also heard stories of the repair only lasting two weeks, then failing under higher coolant temps.
How long did the repairs hold? Are there tricks to getting the JB to adhere, and tricks to sanding it down to the correct height?
04-05-2014 18:36:05
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to RedBarnNate, 04-04-2014 19:14:51
In the 5 or so years I worked there none of the JB repairs came back Has for getting it to stick make shore it is clean one of the guys had a larger washer cut in half and put the emery cloth on it I just folded
It a few times and sanded away
