Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Pitting in o-ring groove in JD 6-404 engine block - Options
RedBarnNate
04-04-2014 15:33:51
108.248.57.181
Hello community! We are part way through an in-frame engine rebuild on a John Deere 6-404 6-cylinder diesel engine. My mechanic notified me that he found some pitting or chips missing in the o-ring groove of at least one hole.
[URL=http://s76.photobucket.com/user/nathonian/media/photo1-2.jpg.html][/URL]
[URL=http://s76.photobucket.com/user/nathonian/media/photo2-2.jpg.html][/URL]
This 4040 tractor will continue to be worked after the rebuild. It spends 6-7 days a week feeding cows on a dairy.
Can anyone with prior experience chime in with recommendations? I'm not comfortable with continue the rebuild before addressing this issue. I have a couple ideas in mind, but would like input from others that have traveled this road before. :)
[Reply]   [No Email]
mike m
04-05-2014 11:04:53
184.20.169.244
 Re: Pitting in o-ring groove in JD 6-404 engine block - Options in reply to RedBarnNate, 04-04-2014 15:33:51
Those that use the JB method why not just put it in there and assemble it quick ???
[Reply]  [No Email]
jd2cylman
04-06-2014 07:38:47
173.23.166.148
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to mike m, 04-05-2014 11:04:53
The idea of the JB Weld is not to glue the o-rings in, but to smooth the ramp so the pits in the ramp do not cut the o-rings. If you put the sleeves in before the JB Weld is hardened, you still risk cutting the o-rings. Let it harden, then sand it down to match the profile of the ramp. Cleanliness is key to a good bond, but usually the pits don't go below the line where the o-ring seals. In the rare case where that occurs the JB Weld needs to stay in place, but mostly it just needs to stay long enough to get the o-rings in place. In all the years I repaired blocks with this method, I never had a coolant leak. YMMV. Machining out the old ramp and pressing in a new ramp still leaves the possibility of a leak between the block and the new pressed in ramp (although very rare, I'm sure). So I guess it boils down to how much you want to spend.
Adrian
[Reply]  [No Email]
RedBarnNate
04-08-2014 10:10:44
108.248.57.181
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to jd2cylman, 04-06-2014 07:38:47
The "worst" looking hole has a place where the "pit" is more of a "chip" where the o-ring seat has eroded away to where the next lower o-ring groove is. I'm not sure how to make the JB or other epoxy "stay" in place until it hardens. Please see the picture of this spot below. I've also copied a page out of the John Deere factory repair manual & edited it to show where the eroded portion is.
[URL=http://s76.photobucket.com/user/nathonian/media/IMG_2460-1.jpg.html][/URL]
[URL=http://s76.photobucket.com/user/nathonian/media/copyfrommanual.jpg.html][/URL]
[Reply]  [No Email]
jd2cylman
04-08-2014 19:56:20
173.23.166.148
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to RedBarnNate, 04-08-2014 10:10:44
I would clean that puppy with a wire wheel, then carefully clean even more with muriatic acid (don't breath the fumes!), then sand well and clean again. Apply JB weld to the spots. Let harden. Sand to match the profile and Bob's your uncle! Install sleeves and go. Just my opinion.
Good luck!
Adrian
[Reply]  [No Email]
Tim S
04-06-2014 08:14:18
107.128.253.113
Yes, I can see this idea working,, though I have never tried it or needed to (Knock on wood),, and I have never heard of doing it the way Kent suggested,,and his way sounds good,,and at $100 a hole it is economical too, you can soon get a couple hours into repairing one with the J-B weld method,,and time is money.. I don"t know if any machine shops around here offer that kind of repair,,but I"m going to inquire about it so I will know,,I am also looking for a shop that can turn my 6 cylinder cranks for me,, my old shop called it quits and retired last year,,Darn it..
[Reply]  [No Email]
JD Dave
04-04-2014 17:24:59
67.84.194.184
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to RedBarnNate, 04-04-2014 15:33:51
Kent,
Can you explain how this machining is done? If you machine away to eliminate the pitting at the upper liner o-ring in the block won't this alter the liner protrusion dimension at the deck?
[Reply]  [No Email]
Kent Petersen
04-05-2014 00:16:14
209.62.225.173
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to JD Dave, 04-04-2014 17:24:59
J D Dave no the liner is set by the depth in the top of the block. the counter bores are cut out with a boreing bar a ledge is left in the bottom and a new counter bore is installed
[Reply]  [No Email]
RedBarnNate
04-04-2014 19:14:51
108.248.57.181
This is exactly what I was wondering. How would it be possible to ensure that the standard length liners protrude within the correct tolerances? Hmm.
I've heard the JB weld method mentioned before. I've also heard stories of the repair only lasting two weeks, then failing under higher coolant temps.
How long did the repairs hold? Are there tricks to getting the JB to adhere, and tricks to sanding it down to the correct height?
[Reply]  [No Email]
Tallpaulw
04-05-2014 18:36:05
75.97.94.167
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to RedBarnNate, 04-04-2014 19:14:51
In the 5 or so years I worked there none of the JB repairs came back Has for getting it to stick make shore it is clean one of the guys had a larger washer cut in half and put the emery cloth on it I just folded
It a few times and sanded away
[Reply]  [No Email]
RedBarnNate
04-04-2014 16:25:51
108.248.57.181
Here are a couple other shots showing the pits in the o-ring grooves (counter-bore?). I also included shots of a few liners. After further inspection, we now see 3 out of 6 holes have some pitting. 1 out of the 3 is not only slightly pitted, but chipped through as well.
[URL=http://s76.photobucket.com/user/nathonian/media/IMG_2459.jpg.html][/URL]
[URL=http://s76.photobucket.com/user/nathonian/media/IMG_2462.jpg.html][/URL]
[URL=http://s76.photobucket.com/user/nathonian/media/SleeveORing5.jpg.html][/URL]
[URL=http://s76.photobucket.com/user/nathonian/media/SleeveORing3.jpg.html][/URL]
[Reply]  [No Email]
Tallpaulw
04-04-2014 18:43:07
75.97.94.167
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to RedBarnNate, 04-04-2014 16:25:51
When I worked for a Deere dealer when we came across this on a rebuild we wire wheeled it clean used JB weld and sand it down with emery cloth to repair the pitting it takes some time saved many a block this way
[Reply]  [No Email]
jd2cylman
04-04-2014 18:49:58
173.23.166.148
 Re: Pitting in o-ring groove in JD 6-404 engine block - Opti in reply to Tallpaulw, 04-04-2014 18:43:07
Same with the old Olivers and Allis Chalmers in the shop I used to work at.
Adrian
[Reply]  [No Email]
tomstractorsandtoys
04-04-2014 18:47:48
64.136.27.162
I have fixed a few that way to. Seems more of a problem on 202,219 and 239's.The 329 in 2840's and 4030's were bads well.
[Reply]  [No Email]
Kent Petersen
04-04-2014 15:59:21
209.62.225.173
J & L premier Auto Tea SD can replace the counter bores as needed for you. don"t know ware you are but there must be a machine shop some ware close that can do it. last ones i had done cost $100.00 per hole thats been 5 years ago
[Reply]  [No Email]
Brian Stortenbecker
04-04-2014 20:00:25
69.80.125.18
 Re: Pitting in o-ring groove in JD 6-404 engine block - Options in reply to Kent Petersen, 04-04-2014 15:59:21
I would not do anything but have it bored and put new counterbores in. You must use a machine shop that has experience with this. I had a case block done, he did the lower and uppers done. I would also have the block decked, he will need a new sleeve to recut the counter bores to get the right liner protrusion. I'm not a fan of reman engines, yes this will cost some money but you should have a perfect engine when your done.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
