Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: H brake job
buck eye al
04-04-2014 15:17:41
It will wet the shoes again if you don't adjust the axle bearings. Been a long time but sticks in my mind a pre load of .010 or maybe only .005" measured at the front & rear of the trumpet bell when attached with only the top bolt is what they want on the axles? I'd have to look it up to be certain!
Last time I was in there on our H was back in the early 80's & I installed a real thin cross sectioned O ring between the brake drum & the seal ring in addition to the sealer Mike mentioned. Don't know if it made a difference but the brakes still work.
Paul Simmer
04-05-2014 14:25:28
 Re: H brake job in reply to buck eye al, 04-04-2014 15:17:41
My SIL is doing brakes on an H today, just tore it apart. I see a name where you ordered the seal, do you have a contact number for that? Thanks.
Jethro Lilley
04-05-2014 17:58:44
 Re: H brake job in reply to Paul Simmer, 04-05-2014 14:25:28
Charles Lindstrom is a retired gentleman in his 70's who loves the H model. He has any most any part you can imagine for an H. You can google his name and go to his site. It has a listing of H parts by part#. Call him at 816 232 5860 and he will return your call. Have your credit card in hand. His prices are great.
Jethro Lilley
04-04-2014 15:52:45
I ordered seals from Charles Lindstrom this morning. He said there is an inner felt seal where you had put the o-ring. There was one in place when I removed the drum. It had formed itself to the spacer on one side and the splines of the drum on the other. Looked like it had been doing its job, as there was no oil leakage in that area. The stains on the rear end and bell suggested that the whole problem was the AH633R seal had failed. I will check the end-play on the axles as you suggested. Thanks.
