TractorLinks.com
Show Parts for Model:
Sealer and Shims
Gary Puckett
04-04-2014 13:17:50
Should sealer be used on the shims that adjust the gear lash between the steering worm gear and the gear in the power steering unit? This happens to be on a 520. Mine is leaking around the shim. I used an old shim, but will replace with a new one(s).
Bob Harvey
04-04-2014 18:20:43
 Re: Sealer and Shims in reply to Gary Puckett, 04-04-2014 13:17:50
Gee willikers, think about it. Did the 'source' of the product use 'sealer'. Give your head a "SHAKE". --more than one -yipes.
Kent Petersen
04-04-2014 16:02:05
replace the o ring on the cap and it won"t leck
jd2cylman
04-04-2014 16:31:38
 Re: Sealer and Shims in reply to Kent Petersen, 04-04-2014 16:02:05
I took it to mean the shims between the worm and the spindle gear to set backlash. Only paper shims there...
Now, for worm bearing pre-load or freeplay, then that cap has an o-ring.
Yes the sealer on the shims add a little thickness. I figure that in. Better than a leak later.
Adrian
Gary Puckett
04-04-2014 16:52:50
 Re: Sealer and Shims in reply to jd2cylman, 04-04-2014 16:31:38
Thanks. It is the paper shim that is leaking, not the cap.
Kent Petersen
04-05-2014 00:21:13
 Re: Sealer and Shims in reply to Gary Puckett, 04-04-2014 16:52:50
the o ring keeps the oil from getting to the shims
Gary Puckett
04-05-2014 08:55:06
 Re: Sealer and Shims in reply to Kent Petersen, 04-05-2014 00:21:13
Kent,
I appreciate your trying to give me a straight answer. I have the manual and have studied the parts diagram. I do not see how the O-ring keeps the oil from getting to the shims. It seems like to me that the oil could come from both sides of the shims. I am talking about the shims between the steering worm housing and the pedestal.
Kent Petersen
04-05-2014 00:20:20
the o ring keep the oil from getting to the shimms
jd2cylman
04-04-2014 14:24:23
The paper shims, yes? They used to have thick and thin ones, now only the thin ones are available. I use a VERY thin coating of Permatex Aviation on all shims. Just enough to seal them all together. Then a very thin coating on each housing.
Adrian
Gtx1967jewison
04-05-2014 02:06:47
 Re: Sealer and Shims in reply to jd2cylman, 04-04-2014 14:24:23
And then they are all garbage the next time they are removed. They were not sealed together from the factory. There's your sign.
Gary Puckett
04-04-2014 15:39:08
Thank you. Both thicknesses are still available from Deere. I ordered them today. I am not sure if they are paper or the harder material.
D-
04-04-2014 14:24:21
Sealer will add to the thickness of the shim.
