TractorLinks.com
Show Parts for Model:
Re: Clutch and flywheel off now how to set end play
Kscole
04-04-2014 04:10:51
O I'm sorry it's A 1937 unstyled A
buickanddeere
04-04-2014 13:54:59
 Re: Clutch and flywheel off now how to set end play in reply to Kscole, 04-04-2014 04:10:51
Call 1-800-522-7448
Ask for the oldest service manual they have for the JD A.
rick deere
04-04-2014 06:53:21
also while crank is to the left sitting on the tractor I think the clutch lever should be pulled back than I put a block of wood between the clutch and tire to keep in over to the left as I push flywheel on, and make sure you have it in time with the marks.good luck
Wilamayb
04-04-2014 05:16:16
I hate to be the bearer of bad news, but you should have left the flywheel on the tractor. The flywheel is what controls endplay. Endplay is set by pushing the crankshaft toward the LH side of the tractor while pushing the flywheel toward the right. Once the proper endplay is accomplished, the flywheel is then tightened down on the crank.
Gtx1967jewison
04-05-2014 02:25:47
 Re: Clutch and flywheel off now how to set end play in reply to Wilamayb, 04-04-2014 05:16:16
Where's the bad news?? He seems aware of your fact, & is asking the procedure for adjusting the end play. It's not difficult, & certainly not "bad news" ?
