Clutch and flywheel off now how to set end play
Kscole
New User
Hey everyone I had my whole clutch drum off and my flywheel at the same time. How do I go about getting the crank end play adjusted where do I start with the clutch adjustment ?
I hate to be the bearer of bad news, but you should have left the flywheel on the tractor. The flywheel is what controls endplay. Endplay is set by pushing the crankshaft toward the LH side of the tractor while pushing the flywheel toward the right. Once the proper endplay is accomplished, the flywheel is then tightened down on the crank.
also while crank is to the left sitting on the tractor I think the clutch lever should be pulled back than I put a block of wood between the clutch and tire to keep in over to the left as I push flywheel on, and make sure you have it in time with the marks.good luck
Where's the bad news?? He seems aware of your fact, & is asking the procedure for adjusting the end play. It's not difficult, & certainly not "bad news" ?
