Jethro Lilley
My neighbor had a B in his barn that he wanted to start up... a 48 model ser 239XXX with round rear axles and a well-engineered 3 pt. It had been painted at some point in the near past and looked real good. He has had it for 5 years and (of course) said the former owner had it running. Ha Ha. I took the carb and mag off. The choke was inoperable as the shaft pin didn't mate with the lever and some of the passages were stopped up. Soaked it, cleaned it and installed a kit. Put it on my B and broke an acre of land. Good. The mag's impulse mechanism was inoperable. No snap, just a 2-fingered click. All the drive parts had wallowed flats so there was 3/8 inch play. Roberts had a 90 dollar impulse kit and points. Fixed that.
Late yesterday I went to his shop and we pulled it out, popped the clutch a few times to unstick the engine, drained the gas/oil mixture from the crankcase and added fresh oil.
Smelling an excuse for a party, the ladies showed up and started cooking soft-shelled crabs, flounder and chicken wings and they all put the heat on me to "Crank her up."
So... I slapped the carb on, cut on the gas and no leaks. Whew. Then, with a young guy to turn the flywheel, we lined up the timing marks on imulse, checked for spark on the top terminal and installed the mag. Rotated the fly around to TDC again and tapped the mag back... all the way and no snap. Thinking I did something wrong, we did the process again... no snap, but when I removed the mag it snapped... something fishy going on here. Took the cap off of the governor and Bingo... the timing marks were off 180 degrees! Tell me again this tractor was running! So... I re-timed the marks, put the mag on, it snapped and I locked her down. With everyone staring at me I applied the choke, gave her half-throttle and hit the starter... 3 revolutions and she jumped to life. Ran real good... idled down well with no hunting. Everybody cheered!
The crabs were good but the flounder was better.
PS... I am not familiar with the old-style hydraulic couplings on this powertrol. These have a ring around the dummy plugs where mine has the spring clip. I need someone to enlighten me on how to remove the dummies and plug up a cylinder. Are the hose couplers the same as a spring-clip model?
