5020 outer tie rod end
36 A
dose anybody have a source for outer tie rod ends for a 5020 ? Or is the inner the same taper a guy could cut the end off and weld it in place ?
Type of axle? Serial #?
A typical outer tie rod end would would be DEERE part #AR74132, @ a little under a hundred dollars. But it gets BETTER. Your DEERE dealer or an independent A&I parts supplier can order the A&I version (A-AR74132) for just over half that.
You can't re-invent the wheel for under $60.00!
(quoted from post at 23:16:15 03/21/14) Type of axle? Serial #?
THAT part number is for INNER tie rod- the outer tie rod is 11 inches long- this part number is not the one needed. I am also chasing outer tie rod for the 5020 with adjustable axle. Watch JD part number- their price is for WHOLE assembly not just outer tie rod
