Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Repair or replace inj pump 5085M?
Tx Jim
03-06-2014 03:44:39
It's not my tractor but belongs to someone on another Tractor forum. He stated tractor had 900 hrs on tach,quit running and local dealer stated inj pump needed replaced to the tune $1700 for pump and $650 for labor. I think $650 to R&R inj pump is way too HIGH
dflippin08
03-06-2014 05:36:56
 Re: Repair or replace inj pump 5085M? in reply to Tx Jim, 03-06-2014 03:44:39
Well, Im assuming that the dealer isnt just guessing at it. Im sure they have been through the proper test to verify the issue. 6 hours is about twice what i think it should take. But it is exactly what I would expect a dealer to charge. Man clocks in on the job. Gets the tractor in the shop. Replaces the pump. Test his repair. cleans the tractor. cleans his bay. Does a write up explaining what was done. All this cost money.
Tx Jim
03-06-2014 06:30:04
 Re: Repair or replace inj pump 5085M? in reply to dflippin08, 03-06-2014 05:36:56
dflippin08 said: (quoted from post at 08:36:56 03/06/14)
Man clocks in on the job. Gets the tractor in the shop. Replaces the pump. Test his repair. cleans the tractor. cleans his bay. Does a write up explaining what was done. All this cost money.[/quote]
After serving several years as a JD dealer service manager I think I fully understand the technicians procedure. You left out the scheduled coffee breaks that the technician "fails to clock out/in" on the repair order!!!! :wink:
PS: you also left out the part about diagnostics.
I personally asked Tim S about R&R time and he thought it was about twice too much.
This post was edited by Tx Jim at 06:33:44 03/06/14.
Tx Jim
03-06-2014 06:51:09
 Re: Repair or replace inj pump 5085M? in reply to Tx Jim, 03-06-2014 06:30:04
Update: Tractor owner reported on the other tractor site that JD dealer is going to replace inj pump under extended warranty under an emissions warranty.
sideconsole4020guy
03-06-2014 04:13:06
Tx. Jim, at the JD dealer I work at we do end up replacing a few HPCR pumps a year. That being said more needs to be known as to what other trouble shooting was done. When we have had to replace pumps it was the last option as we don't just jump in the replace the pump bandwagon because generally those pumps are pretty robust. As far as the labor rate I am not sure as we are not a flat rate dealership and at our labor rate ($105) that seems about right as you have removal, instaliation, test running, clean up. I am not familiar with that engine as far as time for removal goes( I work on combines sprayers and planters)
Tx Jim
03-06-2014 05:22:32
 Re: Repair or replace inj pump 5085M? in reply to sideconsole4020guy, 03-06-2014 04:13:06
Tractor owner stated he purchased tractor with 850 hrs on tach. He performed maintenance(filters & fluid) and 50 hrs later tractor died while applying fert. That's all I know. Man 6 hrs sounds like a lot to R&R an inj pump. I would think it could be accomplished in 1/2 that time. You state your dealership isn't a flat rate dealership but I'll bet JD still pays warranty claims by flat rate similar to when I was dealer service manager.
