5020 pto brake.
Big Jugs
PTO keeps running when lever is in stop position. Why is this? Is this something that can be fixed without splitting?
I think about all you can do without splitting is check for correct operation of control cable and valve operation.
I think the pto brake is close to the front of trans.
Not that it is the exact same but I had 4020 powershift that the linkage was bent, cracked, and loose and a twenty min look under the dash fixed it. So make sure to check everything before you assume it's the brake and split the tractor
