Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Model B clutch bearing
03-04-2014 20:57:42
I have to keep repacking mine. Should have replaced it, but packing it is the easy route so far. Gonna replace it maybe this summer. Just one of those things that can be left alone for a while but needs to be replaced eventually.
03-05-2014 12:12:18
 Re: Model B clutch bearing in reply to MEANJDK, 03-04-2014 20:57:42
If you had the owners & repair manuals, you would know that they are supposed to be cleaned & repacked Every Year. Whenever it's running & the clutch is disengaged, this bearing is whirling away on your crankshaft.
03-05-2014 21:23:55
 Re: Model B clutch bearing in reply to Gtx1967jewison, 03-05-2014 12:12:18
My 51 B has never been rebuilt. Bearing sounds awful. The previous owners didnt know squat about this type of maintanace. I dont run it much. I just keep limping it along, with the clutch engaged while idling. Someday I'll have the time and resources to do a rebuild.
03-06-2014 06:47:37
 Re: Model B clutch bearing in reply to MEANJDK, 03-05-2014 21:23:55
The manual also says the clutch is to be ALWAYS engaged when engine is running. Take it out of gear & engage it. Always. There are two reasons for this. First is SAFETY. If a floating disk breaks in half- and they do- it will lodge between the drive disks & engage the clutch without warning & with no way to stop. This DOES happen. The tractor takes off in whatever gear the operator has it in, VERY dangerous- deadly. The second reason is to avoid massive wear on the clutch bearing, clutch bushing, & Crankshaft. It also wears the locator pin due to rattling around. I cringe walking around shows & seeing all the 2 cyl JD's idling away, with the clutch disengaged ;-(
