Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: JD 2510 transmission problem...need help!
sslong5871
03-04-2014 18:44:06
We will resume working on it tomorrow. Thanks again for the information. I will post results tomorrow.
Bob
03-04-2014 22:52:59
 Re: JD 2510 transmission problem...need help! in reply to sslong5871, 03-04-2014 18:44:06
Sadly, "resuming" work on it tomorrow (if it was towed without the tranny being in tow) is FUTILE, unless you have a LOT of $$$ and time or even more $$$$$$ to pay someone else to repair what you "smoked" by towing it.
NOT trying to be the bad guy, just telling you like it is!
sslong5871
03-05-2014 00:59:49
 Re: JD 2510 transmission problem...need help! in reply to Bob, 03-04-2014 22:52:59
[quote="Bob"](reply to post at 23:52:59 03/04/14) [/quote]the tractor is already split apart and essentially in 3 large pieces, the top shaft is already out...in the whole scheme of things it can't be much more work to get to the bottom shaft. As far as $$, obviously I haven't checked into that yet but I'm sure it's worth fixing rather than junking the tractor.
This post was edited by sslong5871 at 05:03:31 03/05/14.
Tx Jim
03-05-2014 03:33:11
 Re: JD 2510 transmission problem...need help! in reply to sslong5871, 03-05-2014 00:59:49
Do the double gears(parts key #4,#13 & #23) all turn freely on shaft(parts key #22) when in neutral. Look for "blue color" on the galled gear.
Tim S
03-05-2014 04:11:40
 Re: JD 2510 transmission problem...need help! in reply to Tx Jim, 03-05-2014 03:33:11
#13 gear is the one that normally gualds,
sslong5871
03-05-2014 07:23:14
 Re: JD 2510 transmission problem...need help! in reply to Tim S, 03-05-2014 04:11:40
[quote="Tim S"](quoted from post at 05:11:40 03/05/14) #13 gear is the one that normally gualds,[/quote]
#13 is definitely gaulded
thanks for the help!
Copyright © 1997-2015 Yesterday's Tractor Co.
