Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: JD 2510 transmission problem...need help!
LarrySTN
03-04-2014 18:42:22
When you tow a syncro-range with the engine not running it MUST be in the tow position. If not the bottom shaft becomes "welded" to a gear. What you have is a gear welded fast to the shaft on the bottom shaft. You need to remove the bottom shaft and replace all damaged parts. To remove the bottom shaft the axle housings must be removed, along with the differential, also the top shaft needs removed.
Kent Petersen
03-06-2014 10:09:30
 Re: JD 2510 transmission problem...need help! in reply to LarrySTN, 03-04-2014 18:42:22
when towing and not in tow you take out the top shaft. most of the time the rev gear welds to the shaft. i have never see the bottom shaft do that i think if the bottom shaft were to do that it would be because the oil level was very low
sslong5871
03-04-2014 18:44:06
We will resume working on it tomorrow. Thanks again for the information. I will post results tomorrow.
Bob
03-04-2014 22:52:59
 Re: JD 2510 transmission problem...need help! in reply to sslong5871, 03-04-2014 18:44:06
Sadly, "resuming" work on it tomorrow (if it was towed without the tranny being in tow) is FUTILE, unless you have a LOT of $$$ and time or even more $$$$$$ to pay someone else to repair what you "smoked" by towing it.
NOT trying to be the bad guy, just telling you like it is!
sslong5871
03-05-2014 00:59:49
 Re: JD 2510 transmission problem...need help! in reply to Bob, 03-04-2014 22:52:59
[quote="Bob"](reply to post at 23:52:59 03/04/14) [/quote]the tractor is already split apart and essentially in 3 large pieces, the top shaft is already out...in the whole scheme of things it can't be much more work to get to the bottom shaft. As far as $$, obviously I haven't checked into that yet but I'm sure it's worth fixing rather than junking the tractor.
This post was edited by sslong5871 at 05:03:31 03/05/14.
Tx Jim
03-05-2014 03:33:11
 Re: JD 2510 transmission problem...need help! in reply to sslong5871, 03-05-2014 00:59:49
Do the double gears(parts key #4,#13 & #23) all turn freely on shaft(parts key #22) when in neutral. Look for "blue color" on the galled gear.
Tim S
03-05-2014 04:11:40
 Re: JD 2510 transmission problem...need help! in reply to Tx Jim, 03-05-2014 03:33:11
#13 gear is the one that normally gualds,
sslong5871
03-05-2014 07:23:14
 Re: JD 2510 transmission problem...need help! in reply to Tim S, 03-05-2014 04:11:40
[quote="Tim S"](quoted from post at 05:11:40 03/05/14) #13 gear is the one that normally gualds,[/quote]
#13 is definitely gaulded
thanks for the help!
