Wemedeeres
There isn't much that scares me more on these two cylinders than removing the flywheel. That being said I have never done it, maybe it's not that difficult but I've heard some horror stories about flywheels coming loose so I have chosen to stay away from them. This evening I was out in the shop looking over the H to see if there is anything else I should do before I start reassembling the engine. For what reason I have no idea I got the notion to check the flywheel end play, my manual shows 0.005-0.010, my end play is 0.023. According to the manual I need to slide flywheel in to obtain proper clearances. Can I just loosen the nuts and slide it in or do I need to completely remove it and clean the shaft first? After that how tight do I tighten the nuts again so it doesn't come loose but not enough to break the flywheel?
