TractorLinks.com
Show Parts for Model:
H flywheel removal or adjustment for crankshaft end play
Wemedeeres
03-04-2014 16:20:04
There isn't much that scares me more on these two cylinders than removing the flywheel. That being said I have never done it, maybe it's not that difficult but I've heard some horror stories about flywheels coming loose so I have chosen to stay away from them. This evening I was out in the shop looking over the H to see if there is anything else I should do before I start reassembling the engine. For what reason I have no idea I got the notion to check the flywheel end play, my manual shows 0.005-0.010, my end play is 0.023. According to the manual I need to slide flywheel in to obtain proper clearances. Can I just loosen the nuts and slide it in or do I need to completely remove it and clean the shaft first? After that how tight do I tighten the nuts again so it doesn't come loose but not enough to break the flywheel?
Wemedeeres
03-05-2014 07:29:05
 Re: H flywheel removal or adjustment for crankshaft end play in reply to Wemedeeres, 03-04-2014 16:20:04
How do I go about tracking him down on here?
Mike M
03-05-2014 13:06:49
 Re: H flywheel removal or adjustment for crankshaft end play in reply to Wemedeeres, 03-05-2014 07:29:05
I was able to find him in the photo ads for you.
ad # 546255
517-663-6352 is the phone number listed.
Wemedeeres
03-04-2014 19:10:53
Thanks for the advise guys I really appreciate it!! I'll have to try get my hands on one of those wrenches.
D-
03-05-2014 07:05:29
 Re: H flywheel removal or adjustment for crankshaft end play in reply to Wemedeeres, 03-04-2014 19:10:53
Ted Klee in MI has had them for sale on here. Also a socket w/universal should work.
mike m
03-04-2014 17:06:04
The H has notches in the flywheel and a groove in the crank when you loosen the bolts(best done with special wrench)you can pull it on farther with pry bars in that notch.Tighten as tight as you can with factory wrench.
jd50 puller
03-04-2014 16:53:06
When I set the end play on mine I just pulled the top cover off used a small pry bar on clutch side to push crank over easily not prying hard on it and slid flywheel up tight then tapped it back a little watching the end of the shaft where it and flywheel meet and watched how far it moved.
D-
03-04-2014 16:31:12
I just loosen the bolts and bump the flywheel with a rubber mallet. That draws the crank thru same as hitting the end of a sledge hammer etc against the floor to draw the hammer onto the handle. You could also use a block of wood and a big hammer if no rubber mallet.
I have the old flywheel wrench and just go by feel when tightening. Have never had one get loose or break. Maybe I'm not strong enough??
