Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
John Deere A vs. G. differences
Jonathan Gurley
03-04-2014 15:43:01
For those in the know. whats the big differences in the John Deere A vs. G .. horsepower specs and all other specs seem almost identical, and several stories I've read seem to claim that the A does just as good as G's tractor pulling. but anyway was just sorta wanting a history lesson. thanks. for any comment.s
9630T
03-05-2014 13:54:01
 Re: John Deere A vs. G. differences in reply to Jonathan Gurley, 03-04-2014 15:43:01
WE USED TO RUN BOTH A LATE A AND A G WITH 4 ROW FRONT MOUNT CULTIVATORS WE RAN IN 5TH GEAR IF THE CORN WAS BIG ENOUGH,,,,WE COULD EASILY PUT 50 GALLONS OF GAS THRU THE G IN A LONG DAY THE A USED ABOUT HALF AS MUCH AND WE GOT JUST AS MUCH DONE WITH EITHER TRACTOR. WE QUIT USING THE G AND USED A 60 THE POWER STEERING WAS NICE AND THE FUEL USEAGE WAS GOOD.
Jonathan Gurley
03-05-2014 14:59:54
 Re: John Deere A vs. G. differences in reply to 9630T, 03-05-2014 13:54:01
Thanks for the info.. yeh we have about a nice restored 1950 A.. so its a parade/drive around the property tractor lol. I was just curious thanks
donmyeil
03-05-2014 06:50:04
Put them on a big disk in plowed ground , you will see the difference real quick .
clampdaddy
03-04-2014 17:48:55
All of what these guys said. Then there is the sound. My A and my G both have mufflers but you can hear those extra cubic inches in the G. It's kinda hard to explain. Like bass from a stereo I guess. I can hear the exhaust pulses from the A, but I can feel the exhaust pulses from the G.
jd50 puller
03-04-2014 16:47:39
50 51 52 that is the latest model A produced so that would be a late model A. Your looking at about 4.45-4.75 compression on an all-fuel and 5.60:1 on a gas model A not a big difference. Most aftermarket pistons are already made to give higher compression.
Jonathan Gurley
03-04-2014 16:18:50
No sir, not looking to lug it down, just curious to the difference. what is considered a "late" model A.. 1950 and newer for the higher compression??
jd50 puller
03-04-2014 16:03:51
Tractor data.com will give you most of the specs. Engine size on a stock late A is about 321ci and a G is around 412 so there is a big difference rite there. There is about a 5-10 horsepower difference between them as well. But a lot of that can be changed with a good carb, manifold, and proper tuning of the engine. Its all in how you want it to run. Do you want it to lug down a lot?
B-maniac
03-04-2014 15:57:51
Late A and G for comparison. G was all fuel only with ultra low compression , Late A had in gas had higher comp and about the same hp because of it. A was 321 ci and G was 413ci. Get the comp. ratio up on the G and it will come alive with good gas. G is built heavier and that's why pullers want A and stroke the A and get more power yet. Just can't get the G into the lighter classes.
rla
03-04-2014 17:24:26
 Re: John Deere A vs. G. differences in reply to B-maniac, 03-04-2014 15:57:51
G is a Horse, A is a Lighter horse. Once nice thing about a G if you run out of fuel with a G, you won't hafta walk back as far to your fuel tank to carry more fuel to the tractor. A Model A will lead to alot longer walk.
