Rob Maloney
This is in response to TX Jim's earlier help with my John Deere 2630 slow rock Chef response issue. Power steering line is okay, standby pressure is okay, filters and sub screen okay, disconnected the Remotes., rebuilt the loader valve, rebuilt the hydraulic cylinders, rebuilt the rockshaft cylinder with no misting under the cap. Could someone please post a diagram of the 2630s rock shaft three point linkage adjustments and the depth control lever linkage adjustments? Any other ideas or suggestions are welcome. Once you operate the loader valve or turn the steering wheel, the three point works at normal speed for one cycle. If not the three-point comes up really slowly, unless it is underload such as a big bale of hay.
